Leaking weld in bathroom radiator
peterp49
by peterp49 » Mon May 09, 2011 11:38 am
2 bathroom radiators installed 10 years ago have started to leak at the weld between vertical pipes and one of the front panels. Is there any way I can clean these up and cold weld with epoxy? Will this work? Replacements for these radiators cost around £750 each! Any help would be appreciated.
by stoneyboy » Tue May 10, 2011 10:41 pm
peterp49,
You could try adding leak sealer to your heating system but it is unlikely to solve the problem for more than a year or two.
It is currently Fri Jan 10, 2025 10:23 pm
