how to finish patio above DPC
Kevindrich
by Kevindrich » Tue May 10, 2011 10:37 pm
Hi all
My property is on two different levels, I am building two patios with steps leading to the two hights. The problem is the top patio will finish 600mm above the DPC of the lower extension. The extension extends out about 900mm for the main house so the top patio will run into the side wall. How would I finish this, at the moment there is a 400mm gap between the extension and original top patio. This drop is a potential risk to my kids falling down it. I have read about lead flashing being used chased into the brickwork, would this work or do I have to live with a gap. Any help and advise on how to finish this top patio with out causing damp issues.
dpc
by welsh brickie » Wed May 11, 2011 9:10 pm
I would fit an aco drainage system,Its a preformed gully system that directs surface water away from your property.
It is currently Mon Dec 23, 2024 10:33 am
