Board finish or multi?
mark prior
by mark prior » Fri May 13, 2011 9:45 am
I am skimming a small bedroom this weekend two walls need doing i sed this to a friend and thay have given me a two bags of plaster what was left over from the work thay had done last weekend. My question is this the plaster thay have given me is board finish i am not plaster boarding it it is going on to walls that have been plasterd at some piont in it's life would this be ok to use or would i still need to get multi-finish. P.S i am no professioal but i can do it.?
board finish
by welsh brickie » Fri May 13, 2011 7:24 pm
yes its fine,but use a pva solution on the wall first.Multi finish gives you more time to work with though
mark prior
skimmimg ceilings
by mark prior » Sun May 15, 2011 1:23 pm
Thanxs for that welsh brickie. I have done my walls now the next thing is the ceiling as i have never skimmed a ceiling befor i am not sure if i am quick enough to do the ceiling in one go could i do it in two halfs? Also have you got some tips on skimmimg ceilings. And can i use multi-finish for that?
ceiling
by welsh brickie » Sun May 15, 2011 8:47 pm
Yes use multi finish on it But pva it first,You can do the ceiling in two halfs get some milk/beer crates and planks it easier than going up and down a ladder
mark prior
skimming ceilings
by mark prior » Mon May 16, 2011 8:53 pm
Thanxs for that. Also if i do the ceilibg in two halfs do you think i will see the joins the in middel when it drys out?
It is currently Fri Nov 22, 2024 3:03 pm
