What to fix stud wall to
Information, help and solutions to many issues encountered when converting barns and older buildings
10 posts   •   Page 1 of 1
Boothy
by Boothy » Wed May 18, 2011 3:28 pm
I really need help with my renovation. I need to start putting up the ground floor stud walls. At the moment I have the sub floor, not up to finished floor, I need to put down 100mm celotex wet u/floor heating and flow screed but I need to put the walls up first so I dont nail through pipes after the floor is finished. What can I build the wall off?
1:- Build one course of block 150mm heigh
2:- Build two courses of brick 1500mm heigh
3:- Make a temporary support underneath the walls I am building out of wood then remove the support when the wall is complete then the flow screed will seep under the wall for a fix
Does anyone out there know what people do in these situations?
stud wall
by welsh brickie » Wed May 18, 2011 6:07 pm
lay 3x2 tanalised timber in floscreed, when its set solid you can nail your stud to it.
Boothy
Re: stud wall
by Boothy » Wed Jun 01, 2011 12:30 pm
welsh brickie wrote:lay 3x2 tanalised timber in floscreed, when its set solid you can nail your stud to it.
How do you mean. I really want to put the walls up first not after the screed is down. Do you think building a small wall 150mm in height is not a good idea?
Boothy
by Boothy » Wed Jun 01, 2011 12:31 pm
ok
Boothy
by Boothy » Wed Jun 01, 2011 12:33 pm
Really want to put the walls up first is laying a small wall not a good idea then. How do people do this in these cases?
building walls
by welsh brickie » Wed Jun 01, 2011 10:12 pm
you asked for advice,and I am giving you advice on what I do or have done in the past,You say you want to build a 150mm wall first?? we always lay the floor first before building the internal walls.Laying timbers in the floor will eliminate any chance of nailing through pipework and give you a solid base to work off.
Boothy
by Boothy » Fri Jun 03, 2011 2:37 pm
Thanks for the reply, sorry if I offended you. so to clarify do I put the tanilised timber straight on top of the insulation or put it on top of the screed as its being layed?
floor
by welsh brickie » Sat Jun 04, 2011 9:52 am
lay it in the screed as its being laid when its set you can fix to it
elwood
by elwood » Tue Jun 07, 2011 7:46 pm
The method I used for my barn
was build off the "sub floor" using 4" celon blocks (plasterboard and skim)
for non load bearing walls, 1200 gauge polythene, 100mm celotex, very thin layer of polythene stapled and taped to seal against wall, lay exspansion strip around perineter, lay underfloor heating pipes and then liquid floor screed.
Bye
BarryWillson
Re: What to fix stud wall to
by BarryWillson » Thu Jun 05, 2014 8:53 am
Another solution is to fix two layers of plasterboard to each side of the studwork. Dont forget to stagger the positions of sockets and switches on dividing walls
It is currently Wed Feb 05, 2025 6:47 am
