fitting a mixer tap
dexta1954
fitting a mixer tap
by dexta1954 » Sun May 22, 2011 8:20 am
I am converting from hot and cold taps to a mixer tap (which i have not yet purchased), what are the fittings required......Thx [/b]
alavapint
by alavapint » Tue May 24, 2011 10:51 pm
It should be a case of removing the existing taps and then just fitting the mixer in place, and then re-connecting the existing pipework.
If you were to be changing the sink/basin style and using a mono bloc mixer, then you would need monobloc tap tails. I'd personally go for flexible ones as they are easily fitted in confined spaces.
dexta1954
Re: fitting a mixer tap
by dexta1954 » Wed May 25, 2011 10:05 pm
thx for that alavapint
It is currently Mon Nov 25, 2024 10:27 pm
