Flexible tap connector
trogre
by trogre » Mon May 23, 2011 6:10 pm
I am going to replace taps in kitchen and reuse the 15mm flexi connectors.The type are the sort that push into the tap and seal with a O ring before tightening.
I have at present no leaks from these O rings but would like to be ready with new ones just in case they leak after reuse.I see Wicks sell assorted O rings but has anybody got any idea for the size of these rings.The packs come in sizes of 1/16" ,3/32" and 1/8".
Plumbers merchants may even sell replacement rings but again need to know size before I go in.
Thank you for any help.
alavapint
by alavapint » Tue May 24, 2011 11:10 pm
Nobody can guess what make of connector you have, there are dozens of manufacturers of flexi pipes, and I bet they all use similar/diffent sizes.
Why take chances ... just fit new flexi pipes. They are far too cheap to begin worrying about O rings.
http://www.awin1.com/awclick.php?mid=12 ... 00mm/77154
It is currently Sat Nov 23, 2024 10:34 am
