C/H coming on with hot water after draining cold water tank!
karano24
by karano24 » Tue May 24, 2011 6:13 pm
I'm hoping someone can help.
We had to drain the cold water tank in the loft to replace a toilet siphon. That is all fixed and we refilled the tank and found we were getting no hot water from the hot taps. Worked out it was an air lock which we've fixed by blasting mains pressure water up the hot tap.
However, now whenever the hot water system comes on ALL of our radiators are coming on. The heating is switched off.
Has anyone got any ideas what this is and how to fix it?
stokedan1
by stokedan1 » Thu May 26, 2011 10:56 pm
faulty mid positon valve
karano24
by karano24 » Fri May 27, 2011 9:41 am
Thanks for your reply. So it's nothing to do with having drained the cold water tank then?
stokedan1
by stokedan1 » Sat May 28, 2011 8:59 pm
no, draining your CWSC will not affect your heating system, it is more likely your motorised valve has failed
It is currently Tue Nov 26, 2024 3:17 pm
