Protecting underground service pipes prior to compacting
seneca
by seneca » Thu May 26, 2011 2:20 pm
Hi this is a first post for me.
I have dug all the topsoil down to approx 18'' in my 6x8m lawned front garden with a view to putting down MOT type 1 limestone scalpings (40mm-dust) then gravelling
But running along side an existing concrete slab drive I have found three service pipes, these\are:
* a black coated metal cable presumably the electricty approx 1.5'' diam
* an black alcathene water pipe
* a grey/yellow plastic pipe (gas??) about 1.5'' diam
All these run parallel from the street to the house. The soil is clay but is hard subsoil (albeit is a bit soggy at the moment). House was built in the 1950's.
My question is can i put the MOT down and compact it with a vibrating plate without damaging the services. And if not how best to protect them. Will cutting a plastic soil pipe in half and laying over the top do the trick?
Any help would be great, cheers
Rob
by stoneyboy » Sat May 28, 2011 5:17 pm
seneca,
Put a good covering of sand over the pipes, about 75mm should be adequate.
services
by welsh brickie » Sun May 29, 2011 3:52 pm
as stoneyboy says cover with sand but also lay warning tape ontop of it.you can buy it from your local builders merchant
seneca
by seneca » Sun May 29, 2011 9:10 pm
Thanks guys, most helpful. Will get a grab bag and give it a covering before getting the MOT delivered. Cheers.
It is currently Tue Jan 21, 2025 4:33 pm
