shower problems
6 posts   •   Page 1 of 1
dougal
shower problems
by dougal » Thu Jun 21, 2007 12:46 pm
i have just fitted a new shower to existing cable and plumbing, at first had no problems but, two weeks later the 30 amp fuse blew so I replaced it as it was about eleven years old so i thought problem solved,but one week later that one blew aswell,any ideas as to what ive done wrong?
Jeffmo
by Jeffmo » Thu Jun 21, 2007 11:42 pm
please give watts of shower and possible size of cable used .Then ideas will be forthcoming .Regards Jeff
by sparx » Thu Jun 21, 2007 11:54 pm
HI check rating of new shower, ie each kWATT DRAWS ABT 4.2Aso if new one over7.5kW. it will melt fuse to protect circuit cable, thats its job!, regards SPARX
dougal
by dougal » Fri Jun 22, 2007 10:29 am
ive cheaked the rating its 10.5Kw does that mean I need to put in new cable
by sparx » Fri Jun 22, 2007 8:56 pm
Hi agn Dougal, Most likely needs larger cable, isolator sw also may only be rated for 30A, 10.5 X 4.2A = 44.1 Amps so no wonder fuse melted!
If you are in England this is controlled service under part P of bldg regs so not DIY legally, regards SPARX
dougal
by dougal » Fri Jun 22, 2007 9:11 pm
ok thanks sparx will get a pro in to do the job thanks for advice.dougal.
It is currently Fri Dec 13, 2024 12:53 am
