by sparx »
Fri Jun 22, 2007 9:25 pm
Hi, best to go with solid wall....
lathe & plaster too thick/uneven to use clip in 'plasterboard' box, assuming you could 'fish' the cable down inside wall you could cut lathes against side of timber stud & carefully cut a box hole and fix thro the side of a metal skt box into stud but suspect lots of broken lathes, & nothing to 'make good' to, sorry not much help but have been there!
regards SPARX
