Quarry Tile
denboy09
Quarry Tile
by denboy09 » Sun Jun 26, 2011 8:37 pm
Have laid quarry tiles in hall way, very clean job very little adhesive on the top or side of the tiles.
My question is. Do i grout first then use a cement & lime film remover then seal with impregnator or seal, grout then use cement & lime film remover? :?
by stoneyboy » Mon Jun 27, 2011 10:18 pm
denboy09,
I would grout first cleaning the tiles carefully as you go, then clean with acid.
Because QTs are not porous the seal will not penetrate the surface so it will wear exposing the duller tile beneath.
Try using a tile polish instead.
denboy09
by denboy09 » Tue Jun 28, 2011 4:38 am
It is currently Fri Nov 22, 2024 4:10 am
