Replacement External Door
Peter Dixon
by Peter Dixon » Fri Jul 08, 2011 11:36 am
I need to replace a modern but rotten back door but the standard 838mm width is 7mm too small. The existing is 845mm x 1962mm - there is already the usual 2-3mm gaps all round (I assume the standard length of 1981mm can be cut down without problems).
Any suggestions? I do not really want to replace the frame if I can help it.
Trades Master
by Trades Master » Sat Jul 09, 2011 5:09 pm
This seems a lot to cut of the new door i would recomend you replace the frame, This is not hard to do, if you have the right tools you can have the job done in 2 hours.
door adjustment
by welsh brickie » Sun Jul 10, 2011 8:23 pm
buy a length of timber,and have it planed to the thickness you require.And then glue and nail it to the door.
greggy
Re: door adjustment
by greggy » Sat Jul 16, 2011 1:02 pm
[quote="welsh brickie"]buy a length of timber,and have it planed to the thickness you require.And then glue and nail it to the door.[/quote]
i had the same problem a few years back.
i did the same as welsh brickie said. but i got some matching mahogany
and put it on the hinge side.
It is currently Fri Nov 22, 2024 10:37 pm
