by welsh brickie »
Fri Jul 15, 2011 6:00 pm
I assume you have a polycarb panel roof.So what you need to do is remove the top capping first and remove the panel.
Take the end cap off by unscrewing the screw,Then with a flat screwdriver ease the cap off it clips in so its quite easy to remove.
Then remove the panel and refit the seal,and refit the panel.You are best to use a hammer and a block of wood to put the capping back.
