toggle light switch
marcuso
toggle light switch
by marcuso » Tue Jul 19, 2011 4:00 pm
The toggle on a switch moves up and down but doesn't switch the light and it feels 'loose'. Can this be repaired? I see there are two tiny holes on the ring at the base of the toggle which look as if a tool could be used to unscrew ring.
Markus O
by ericmark » Tue Jul 19, 2011 11:17 pm
Unlikely the norm is overheating due to bad contact and melting the plastic inside.
marcuso
by marcuso » Wed Jul 20, 2011 10:56 am
ericmark wrote:Unlikely the norm is overheating due to bad contact and melting the plastic inside.
Thanks. The switch never felt hot. Guess I'll buy a new switch if I can find one the same (to match another in the room - or I'll need to buy two!)
by ericmark » Thu Jul 21, 2011 5:35 pm
The very small spring loaded plunger which would likely melt would not likely transfer enough heat for the fault to be seen without disseminating the switch.
It is currently Wed Jan 15, 2025 6:52 pm
