TOILET SEAT
Davie-boy
TOILET SEAT
by Davie-boy » Fri Jun 22, 2007 10:01 am
After many attempts to resolve a sliding seat including 3 replacements i am still having to repeatedly re-attach the seat to a fixed position. I have tried an extra washer at 1 side to no avail. The current seat is a £40 best quality i could find and it is also moving now after a reasonable run of about 4 months in place. Could it be the design of the WC? I have had the same WC for 6 years & always had a seat that inevitably ends up slipping about.
any help in this matter?
louise1968
by louise1968 » Sat Jun 23, 2007 12:04 am
im having the same problem...put new hinges on also... same thing happening....... but dont think its my wc... same thing happened with old one too.... i know wat they say about quality... but seat cost...20 and new hinges 8 pounds... so its mounting up... my last seat cost only 8 pounds from b and q..and never moved once.. been told to try ..locktite thread lock...because bolts are moving causing whole thing to loosen....
DONFRAMAC
TOILET SEAT
by DONFRAMAC » Sat Jun 23, 2007 4:06 am
After replacing many hinge-block & gasket sets, I went to a major plumbing supplies outlet, and came away with a pair of chrome-steel elbow-fittings, and plastic wing-nuts for below. These replace the end-blocks, gaskets, and hinge-rods. That was about 4 years ago, and the seat has given no trouble since. Cost less than 20 fags.
It is currently Mon Dec 23, 2024 8:49 am
