Need advice on filling hole in ceilin
Mikedbu
by Mikedbu » Wed Jul 20, 2011 3:13 pm
Hey I need some advice please. I need to fill a hole in a ceiling were the 4inch soil pipe goes through the ceiling. All the way around the pipe in a hole about 3/4inch bigger than the pipe. Any one got any ideas on the best way to fix this? Thanks for any help.
Mikedbu
by Mikedbu » Wed Jul 20, 2011 9:08 pm
Am hoping to plaster it i just need to get something in the whole so I can plaster on it it with it beging circliar around the soil stack is hard to get any plaster bord in there.
ceiling repair
by welsh brickie » Wed Jul 20, 2011 9:35 pm
you will need plasterboard and drywall adhesive.
Measure and cut a square bit of plasterboard a bit larger than the hole.
Score the plasterboard down the middle and snap it in half.
Drill the cut board and fix string through it.
Mix and lay the adhesive around the inside of the hole.
Bend the plasterboard so it fits inside the hole,and use the string to hold the plasterboard tight against the adhesive.
when set cut of the string and use the dry wall to build out the thickness to the required depth, and plaster smooth with polyfiller or finish plaster
chris_on_tour2002
by chris_on_tour2002 » Sat Aug 06, 2011 1:41 pm
could you box in the pipe?
It is currently Sat Nov 23, 2024 1:15 pm
