DIY block built extesion
vonspritz
by vonspritz » Wed Jul 27, 2011 2:21 pm
Hi all
I'm self building a two storey extension using blocks. My question is this: how vertical is vertical? the blocks vary in size, making it difficult to be exact. I can get a true vertical by working against a batten when coming off the existing wall, but the free standing end is more tricky. Is there any leeway, and if so how much? No good saying leave it to the experts, cos then it won't get done.
Vonspritz
Re: DIY block built extesion
by welsh brickie » Wed Jul 27, 2011 6:09 pm
[quote="vonspritz"]Hi all
Vonspritz[/quote]
all blocks&bricks vary in width sizeby a few mm,only use your level on one side you will never get it plumb (vertically straight), if you try to level both sides.
vonspritz
by vonspritz » Thu Jul 28, 2011 11:56 am
Thanks for your answer, but the main point of my question is, when I get to roof level, about 5 metres, say, is there a maximum amount that the wall can be out of true and be still viable, or within acceptable limits?
blockwork
by welsh brickie » Thu Jul 28, 2011 5:53 pm
unfortunatly I cant answer that question,that will be upto the building inspector,if its out by quite a few inches he can make you do it again
trand
by trand » Tue Aug 02, 2011 3:09 pm
The external should be quite easy to keep level unless you are laying the blocks/bricks form the inside, just keep the level on the outside of the blocks the internal is in the cavity, so dos'nt matter,
It is currently Thu Nov 21, 2024 6:20 pm
