by dmrltd »
Sun Aug 14, 2011 11:19 am
With the moulded doors, you may have to rebuild the top or/and bottom if you take 25mm or more off as you will be removing the rail that adds to the support of theface moulding .
The best bet would be to cut the door then remove the moulding off the side of the timber you have cut off, then you will have a piece of timber the same size to go back in, then you will have to push it up into the cavity glue it and cramp it then you should be ok.
Hope this makes sense and good luck
