I have a electric water pump which pushes water up to the top floor bathroom from the hot water cylinder on the ground floor
The pump automatically switches on when the tap is opened (well - most of the time anyway - separate issue!)
Being forgetful, sometimes the tap is left on and narrowly avoided flooding the bathroom a few times...
Does such a device exist that would start a timer when the pump is activated and cut the power after, say, 15 mins? If the pump is on for less than this then the device should also automatically reset the timer for the next time.
Anyone ever come across such a contraption??
Thanks in advance!!
