washing machine plumbing
6 posts   •   Page 1 of 1
maf67
by maf67 » Sat Jun 23, 2007 2:56 pm
I would like to move my washing machine. Does it matter how far from the sink it is?
by htg engineer » Tue Jun 26, 2007 8:07 pm
If the waste from the washing machine is connected to the sink trap then yes it does, unless there's somewhere you can put a seperate waste pipe in for the washing machine.
The hot and cold water pipes will be ok, as you should be able to move these to where ever you want, but don't try extending the waste hose from the washing machine.
maf67
by maf67 » Wed Jun 27, 2007 9:07 pm
Cheers. Many thanks :D
jogger321
by jogger321 » Thu Jun 28, 2007 9:20 pm
As someone who has purchased a waste extension hose kit in order to move a washing machine further away from the sink..i'd be grateful if you could elaborate on why I should not have done this!
jondeau
by jondeau » Fri Jun 29, 2007 9:45 am
It's all subjective really....
....personally I don't like to connect machine wastes to sink traps at all as every time the d*mm machine empties it blows the waste plug out of the sink and you lose all your washing up water.......infuriating!
JD.
maf67
by maf67 » Tue Jul 10, 2007 9:41 pm
Thanks for the info :D
It is currently Sat Nov 23, 2024 5:08 pm
