by brad »
Sat Jul 07, 2007 9:56 am
Ramie, im not sure i understand your question, if you are asking how tall the frames would be, then they generally are standard height 2100mm. The fixings would be the same as a dwarf wall cons, through the sides into the wall (packed off to get plumb) through the bottoms of the frame into the floor and through the head into the ringbeam. I would suggest you request that your frames are joint using a 10mm ali coupler or equivelent as this adds needs strength when not having a dwarf wall. The standard 'H' section for joing frames together is in my opinion too weak to support full height frames. Hope this helps.
Brad.
