ELECTRIC UNDERFLOOR HEATING
jemball
by jemball » Tue Aug 23, 2011 12:25 pm
Our bathroom has newly installed electric underfloor heating. The cable is covered with 10mm porcelain tiles on quick-set adhesive. How long should we wait after completion of tiling before using the underfloor heating so as to not adversely affect the adhesive?
BLAKEY1963
Re: ELECTRIC UNDERFLOOR HEATING
by BLAKEY1963 » Tue Aug 23, 2011 9:21 pm
JEMBALL
Your electrician who installed it should be able to give you the information from the manufactuers
guidelines on installation methods.
BLAKEY1963
by ericmark » Wed Aug 24, 2011 7:13 am
When we had it laid a week later it had still not set. We had to lift all tiles and re-lay with same make and type of adhesive but different tub and batch number.
All you can go on is the info on the tub. And if it has not set in time stated likely cement has gone off before it was laid.
jemball
by jemball » Wed Aug 24, 2011 11:17 am
Thanks guys for your most useful information.
It is currently Thu Nov 21, 2024 11:06 pm
