Tripped MCB
timcornell
Tripped MCB
by timcornell » Sat Jun 23, 2007 11:45 pm
Hellllllllp!
A few days ago the upstairs lighting MCB tripped off. After Inspecting the bathroom light fitting I discovered that the blocked off red wires had become worn and were in contact with the metel light fitting causing it to short out. I repaired this but now the MCB wont push back. I've tried turning the mains off first but still no joy! Its a fairly new MK Consumer unit.
Any advice?
BLAKEY1963
Re: Tripped MCB
by BLAKEY1963 » Sun Jun 24, 2007 6:39 pm
[quote="timcornell"]Hellllllllp!
Any advice?[/quote]
timcornell
BECAUSE OF EXCESSIVE FAULT CURRENTS THE MCB COULD
BE DAMAGED BEYOND NORMAL SERVICE AND MIGHT NEED
REPLACING.
U WOULD BE WISE TO CONSULT AN ELECTRICIAN ABOUT
POSSIBLY CHANGING THIS AND IT WOULD BE WISE FOR HIM TO CHECK WIRING AFTER HIGH FAULT CURRENTS FLOWING.
OF COURSE WE R ASSUMING THAT THERE IS STILL NOT A SHORT CIRCUIT OR ANOTHER FAULT ON THESE CABLES.
ANOTHER REASON TO GET ADVICE
BLAKEY1963
ON THE CABLES
It is currently Fri Dec 13, 2024 1:08 am
