Light fitting
Peter C
Light fitting
by Peter C » Sat Mar 10, 2007 10:03 am
I have a ceiling rose just as shown in your lights page - two reds two blacks and an earth - but my BHS light fitting has a plastic box with just three holes on the other side out of which come a brown, blue and earth
Do I put the two red in opposite the brown and blacks opposite the blue or what?
thedoctor
by thedoctor » Sat Mar 10, 2007 12:12 pm
See the project on replacing a light fitting Peter. Your light switch interupts the live feed to the light so the live (brown) cable of your light fitting goes to waht is called the switch live in the rose. Effectively the power comes from the feed, through the switch, to the light and back to complete the circuit. The wires coming out of the switch should actually be red as both are, when the switch is on, live. 99.9% of the time one of them is black as normal circuit cable is used, this cable should be tagged with red tape to show it is live.
thedoctor
by thedoctor » Fri Mar 16, 2007 2:32 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Thu Dec 12, 2024 6:45 am
