New kitchen tap
gazza89
New kitchen tap
by gazza89 » Thu Sep 08, 2011 6:00 pm
Hi i am having a problem fitting a tap.
I have this Google "notjusttaps.co.uk/spares-hose-pull-out-nylon.htm" but i need to contect it to the tap which is 3/8.
Is there a connector that i can get for this, any help would be great.
ccltd
Re: New kitchen tap
by ccltd » Sun Sep 11, 2011 11:50 am
What size pipe are you joining on too? 15mm or 22mm
You can just buy a fexi hose which are avilable from screwfix or BNQ
scheissefuergehirn
Re: New kitchen tap
by scheissefuergehirn » Fri Nov 04, 2011 10:41 am
I had to change a 3/8th fitting recently and I had to go to a specialist builders merchant for the fitting as B & Q didn't stock the part (even though it was from their bathroom suite)
mathewleo
Re: New kitchen tap
by mathewleo » Wed Nov 16, 2011 10:34 am
Just tell us the size of the pipe. There are connectors available in the market which can be used but it depends upon the size of the pipe.
It is currently Fri Nov 22, 2024 2:32 pm
