low voltage halogens
Gaz
by Gaz » Sat Mar 10, 2007 10:29 am
when replacing a central ceiling light with say 8 low volt halogens is it better/easier to use a central transformer where the existing wiring is or use fitings with individual transformers? Also what is the technique for fitting if you cant access from above?
thedoctor
by thedoctor » Fri Mar 16, 2007 2:33 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Sat Nov 23, 2024 7:43 am
