fixing corrugated sheets
Doris shut
by Doris shut » Sun Sep 18, 2011 3:02 pm
I hope someone can help with this.
I want to cover an alleyway with corrugated plastic to use for storage.
It’s 2m wide x 3m long. There are built up walls on three sides. I’m screwing battens to these sides with a purlin to support the middle. I’m not sure how to fix the final sheet. I won’t be able to reach to secure it. Someone suggested to fix from the inside with a toggle fixing but I’m not sure. Any advise will be welcome.
Chris
Re: fixing corrugated sheets
by welsh brickie » Mon Sep 19, 2011 5:31 pm
you normally start 1 end to the other,and lean over to fix it with a screwcap and rubber gromit ,but if you cant do it,use clear silicone and lay a bead of sealant the entire length before laying the sheet on top then lay something heavy on top for the mastic to squeeze tight against the other.
It is currently Mon Jan 06, 2025 6:32 am
