rendering
dan007
rendering
by dan007 » Tue Sep 20, 2011 9:07 pm
hi been plastering and rendering a few years lately having a problem with render blowing cracking and sometimes top coat appears weak ie easily marked when ladders leant against them i always soak walls first with water use washed plastering sand 4 sand 1 cement use addmixture everbuild 3 in 1 premium waterproofer plasticiser to slow down setting time then soak the scratch coat then apply top coat with 5 sand 1 cement again with add mix as above then float wall and sponge granted last job was on relatively hot day and sun was on wall all afternoon please advise
Re: rendering
by welsh brickie » Wed Sep 21, 2011 7:09 am
use a pva solution on the scratchcoat just before 2nd coat and add pva to the final mix.You dont need waterproof in the top coat just plastiser.
dan007
Re: rendering
by dan007 » Thu Sep 22, 2011 5:54 pm
thanks was always taught not to use pva with cement though
Re: rendering
by welsh brickie » Fri Sep 23, 2011 7:21 am
[quote="dan007"]thanks was always taught not to use pva with cement though[/quote]
I have never heard of that,but if you dont want to use it you dont have to,its like adding a resin to the mix
dan007
Re: rendering
by dan007 » Sat Sep 24, 2011 7:14 pm
many thanx your a star
It is currently Fri Nov 22, 2024 2:22 pm
