Stud wall in a shower
stiz
by stiz » Tue Jun 26, 2007 5:06 pm
I am extending my ensuite so I can fit a larger shower tray. This means I will be building a new stud wall which will form one side of the shower. Can I just plasterboard this and tile on top, or should I install some form of vapour barrier between the plasterboard and the tiles?
martin497
late reply to question as to which plasterboard.
by martin497 » Tue Jul 10, 2007 3:47 pm
Hi, you have probably done the job by now, but in case you havn't you should really use aqua panel boards in a wet area.
If you have already put up ordinary plasterboards a good tip would be to give them a flat skim with a good quality waterproof adhesive prior to tiling.
It is currently Fri Jan 03, 2025 4:49 am
