SOUND PROOF CEILING WITH EXPANDING FOAM
Jay-Z
by Jay-Z » Thu Oct 20, 2011 6:06 pm
I need to sound proof my bedroom ceiling from a noisey flat above, the ceiling is about 16 metres sq. I live in a Victorian conversion flat. The ceiling just has plasterboard over the joists and no insulation. I am intending to screw up a new layer of 12.5mm thick sounbloc plasterboard over the existing ceiling to block out noise. I didn't want to lower my ceiling so I wanted to avoid leaving a small gap between the two layers.
But I have heard that insulation is key to blocking out noise. I wondered if it would be a good idea before I put up my new soundbloc board, to drill small holes in the existing ceiling and spray with expanding foam to fill the void above. I saw that Wickes sell expanding foam in 300ml size cans. It states it has sound proof qualities. Is this a good idea? Will this help block out sound? Is this safe? How much coverage would I get wth a can?
Any advice would be great.
Re: SOUND PROOF CEILING WITH EXPANDING FOAM
by welsh brickie » Fri Oct 21, 2011 11:15 am
Not a good idea it will just expand and fill the void but noise will still travel through the joists,and besides the ammount of cans you will use will be expensive.
A suspended ceiling is better so you can fill with insulation, and it will help with your heating bill and cut the noise down considerably.
It is currently Mon Jan 06, 2025 8:07 pm
