Horse Stable
stevcolx
Horse Stable
by stevcolx » Tue Nov 15, 2011 9:19 am
I have a horse stable built directly onto a concrete block. I have a problem with water getting into the stable and horse pee travelling through. What do I use to seal the stable/concrete join thus stopping leaks and protecting the wood?
Thanks in advance!
Stable End.jpg (42.51 KiB) Viewed 3426 times
Re: Horse Stable
by welsh brickie » Tue Nov 15, 2011 1:52 pm
any sealant painted on the floor would wear and be insufficent to stop water entering the stable.
It would be better to paint the floor with a pva solution and lay a sand&cement smooth screed of approx 50mm on top of the existing concrete.
stevcolx
Re: Horse Stable
by stevcolx » Tue Nov 15, 2011 10:51 pm
PVA solution? What is that? Everytime I do a search it says it is 'Slime'!!
Re: Horse Stable
by welsh brickie » Wed Nov 16, 2011 7:18 am
PVA is a glue that will adhere the two substances together,It can be found at any builders merchants with instructions on how to use it.
stevcolx
Re: Horse Stable
by stevcolx » Wed Nov 16, 2011 6:55 pm
Thanks for the tip. I'll have a look for the PVA!!
It is currently Mon Jan 06, 2025 8:11 pm
