Shower tray replacement!!
cavalino
by cavalino » Fri Jun 29, 2007 2:51 pm
Can any one advice i have at the moment a downstairs shower on a concrete floor that has a pump fitted to the waste outlet and discharges into a 15mm pipe the waste plug is the same as any other shower.
My question is can i change the shower tray still using the waste system??
plumbers1
Shower tray
by plumbers1 » Sat Jun 30, 2007 12:40 am
Should not be a problem. Sounds like you have a macerator type water discharge pump that pumps the waste water up and out. If so this will not be a problem.
It is currently Wed Nov 27, 2024 11:45 am
