Can move slates inside roof space
Hayct
by Hayct » Fri Nov 18, 2011 9:44 pm
I have just had my roof re-slated and I find that a lot of the slates feel loose/floppy under the sarking. I suspect that roofer has made a mistake with the spacing of the battens. If I ignore this what are the long term effects likely to be. The problem is complicated because I am now having solar panels installed.
Re: Can move slates inside roof space
by welsh brickie » Sat Nov 19, 2011 1:11 pm
you could sprayfoam the area to secure the slates,you can purchase it from www.expandingfoamkits.co.uk
or have company install it for you.
If you leave it, strong winds could dislodge the slates and make it hard to repair because of the installed solar panels.
Hayct
by Hayct » Sat Nov 19, 2011 3:34 pm
Thanks for that. If I had it sprayed with foam would the sarking have to be cut back?
by welsh brickie » Sat Nov 19, 2011 8:20 pm
its best to remove all the sarking, so that the foam has the best chance to adhere to as much surface as possible.
It is currently Mon Jan 06, 2025 6:26 am
