Concrete Slab with footings advice needed please
dunny1234
by dunny1234 » Tue Nov 22, 2011 6:45 pm
I'm preparing ground for concrete slab. I've now dug my slab area (10m x 6m), and 225mm deep footings around the perimeter and up the centre as recommended by structural engineer (where timber frame panels will be).
I've started to lay my sub-base (803), next will be a layer of sand. After this i plan to construct my formwork around the perimeter, lay my DPM, place steel mesh and then pour concrete.
I think i'm doing this the correct way? Any advice would be gratefully received? Really want it to be right before the scary pour of concrete
Thanks in advance
Re: Concrete Slab with footings advice needed please
by welsh brickie » Wed Nov 23, 2011 7:27 am
you will have to contact the building control officer before you proceed to pour the concrete.He is the best person to advise you
bob2012
by bob2012 » Tue Feb 14, 2012 10:22 am
If you’re having problems calculating how much concrete you need, Google "tarmac.co.uk/concretecalculator"
It works quite good on my moby as well.
- Bob
It is currently Sat Nov 23, 2024 1:27 am
