Plastic pipe to copper connection with copper push fit.
gotabelt
by gotabelt » Thu Nov 24, 2011 2:16 pm
Need to join 15mm plastic to 15mm copper using copper pushfit fittings. Will I get good water tight seal?
plumbbob
Re: Plastic pipe to copper connection with copper push fit.
by plumbbob » Thu Nov 24, 2011 3:56 pm
Should do.
gotabelt
by gotabelt » Thu Nov 24, 2011 8:09 pm
Thought I might. Thanks for the reassurance.
P
alavapint
by alavapint » Fri Nov 25, 2011 6:28 pm
Dont forget your support sleeve for the plastic pipe..!
gotabelt
by gotabelt » Sat Nov 26, 2011 1:19 pm
OK I won't
Peter
It is currently Fri Nov 22, 2024 11:47 am
