Rads not coming on
nick108
Rads not coming on
by nick108 » Fri Nov 25, 2011 8:26 pm
We have had a new worcestor twin star 30cdi boiler and new central heating installed.
I have 7 radiators downstairs and 8 upstairs. I am finding that on occasion 1 rad downstairs wont come on and 2 upstairs.
The builders has tried removing air, balancing, replacing thermostats, turning up the heat on the boiler , none of these have solved the problem.
It is strange because occasionally they have come on, but then other rads wont come on. This week the problem has been consistent.
Anyone have any ideas what we should be looking at.
Many Thanks
Nick
plumbbob
Re: Rads not coming on
by plumbbob » Fri Nov 25, 2011 8:45 pm
It could be trapped air simply blocking the pipes and moving about causing the intermittent heating that you describe.
With the heating on, try shutting entirely all the radiators that are getting hot. This may force the blockage into the radiator where it can be bled off.
PowerFlushAssoc
by PowerFlushAssoc » Wed Nov 30, 2011 6:30 pm
I assume open vented:
The hot water flow circuit needs a valve to restrict flow through it. When the hot water circuit comes on and there is no restriction, the water simply goes the easiest way - 80% through the hot water circuit leaving 20% for all rads.
The other option is pieces of sludge or debris in the pipes moving around under different flow conditions. If your water is black - power flush the whole system. Draining it down will not be enough.
