by Paul2463 »
Sat Jan 14, 2012 8:28 pm
Hi PC6844
The maximum memory of any system is a factor of the BIOS and software that the motherboard uses to bring the computer live and run before handing over to the Operating System. The maximum figure is hard coded into the motherboard software, you could put more memory in than the 1GB it says is the maximum but you run the fact that the system will not recognise the module at all, or that it may recognise the module but only be able to access 1GB of that module
To make a long story short, it is not worth the money or the risk to try and place more than the stipulated maximum memory into any computer.
