Bathroom tiling: Can I tile directly onto exposed blockwork?
slongstaff
by slongstaff » Thu Dec 15, 2011 2:01 pm
I'm retiling my bathroom. In taking of the existing tiles, almost all of the plaster and bonding coat is coming away too, exposing the concrete blockwork. Is it advisable to just use that flat and level blcokwork surface to tile directly (porcelain tiles) or should I fit plasterboard and tile to that?? Thanks!
Re: Bathroom tiling: Can I tile directly onto exposed blockw
by stoneyboy » Fri Dec 16, 2011 6:04 pm
slongstaff,
If the surface of the block is stable (ie not dusty) you could tile direct but will probably use a lot more adhesive.
You could dry line with plasterboard but use tile-on board in areas that may get wet.
It is currently Thu Dec 12, 2024 6:29 pm
