High pressure tap on low pressure system
Variable
by Variable » Mon Jul 02, 2007 10:14 pm
Hello again,
I am thinking of fitting a pullout spray tap on our kitchen sink. the ones I have seen so far indicate that they should only be fitted to a high pressure system. As ours is low pressure (gravity fed hot water) what would happen if the kind of tap I mentioned above was fitted?
I imagine the flow of the hot water would be very slow. would this be the case?
regards Variable
oldie
by oldie » Sat Jul 07, 2007 11:58 pm
Yes - unless you drove it with something like a shower pump.
Variable
that old high pressure tap thing
by Variable » Tue Jul 10, 2007 9:46 pm
Many thanks, all received. over and out.
Variable
It is currently Sat Nov 23, 2024 9:19 pm
