tv wall fixing
tvroom
tv wall fixing
by tvroom » Fri Dec 16, 2011 5:24 pm
Need to fix 42" LCD TV to plasterboard on stud wall. TV wall mounting kit has huge nails that will go through to next room so will not work. So how can we safely put TV on wall and also hide the many cables across the back to the power point?
Re: tv wall fixing
by stoneyboy » Fri Dec 16, 2011 6:08 pm
tvroom,
Cut away the plasterboard where the bracket will fit and down to the socket.
Reinforce for fixing the bracket, run the cables and refit the cut out plasterboard.
It is currently Mon Dec 23, 2024 10:22 am
