Should I change my plastic 25 gallon tank?
wolfytom
by wolfytom » Tue Jul 03, 2007 1:16 am
I want to fit a power shower but the manual recommends 230 litres - my calculations make 25 galls equal to 113 litres. How long will that last?
Should I fit a second tank?
Thanks in anticipation...
Andy
wolfytom
by wolfytom » Tue Jul 03, 2007 11:51 pm
thanks in anticipation of ..............
sfa
DONFRAMAC
by DONFRAMAC » Wed Jul 04, 2007 12:29 am
230 litres sounds about right for the loft header-tank, as it feeds the cold input to the shower, as well as repleneshing the indirect hot-cylinder.
I have used a power-shower, supplied from a 210 litre indirect cylinder and loft header you have recommended to you.
After a year of 3 showers back-to-back, the twin-impeller pump siezed as it was not continuously rated.
Choose your brand and power of pump carefully ;--- durability costs money.
ps My loft header-tank has a 22 mm feed to the ball-cock.
wolfytom
by wolfytom » Wed Jul 04, 2007 1:18 am
many thanks - im thinking about attaching a second 25 gall tank by two 22mm pipes.
It is currently Sat Sep 28, 2024 11:31 pm
