Large span lintel
Ask questions and find answers on a range of subjects relating to self build projects
mcjford
Large span lintel
by mcjford » Tue Dec 20, 2011 6:21 pm
I am putting in a 4790 bi fold door and need to find a cavity insulated lintel to fit the opening which would be 5090 minimum does anyone know where i can get one ?If not is there another way of bridging the gap to building regs ie steel beams etc?
Re: Large span lintel
by welsh brickie » Wed Dec 21, 2011 1:31 pm
search CATNIC lintols they will calculate the the load and supply to your specifications.
xavi99
by xavi99 » Wed Dec 21, 2011 7:47 pm
You could also speak to your local steel fabricators. They usually employ an in house engineer who can calculate a steel beam size. This will usually be cheaper than any of the big lintol manufacturers such as Catnic, IG, Keystone, etc,.
However, you may have to install a cavity tray above to prevent damp penetration.
hth
xavi
mcjford
by mcjford » Fri Dec 23, 2011 4:30 pm
Cheers lads thankyou for your help.
It is currently Fri Jan 03, 2025 12:52 am
