ignition spark on oven
tidy
by tidy » Fri Dec 23, 2011 1:10 am
ignition spark keeps going when the oven gets hot . this dose not happen when using the grill or top burners only when i use the oven. got any idea what is wrong. thanks.
tidy
Re: ignition spark on oven
by tidy » Thu Jan 05, 2012 10:46 pm
just to let you lot out there know as i have had no reply.
what caused this problem just in case someone has same trouble.
it was where the wife had cleaned oven with .oven pride then rinsed of after an over night standing.
must have been damp and shorted ignition spark as its OK now after two runs of the oven.
irfan
by irfan » Sun Mar 25, 2012 7:08 pm
In my opinion please check out the ignition switch for stains and grease particles. Remove the knob or button cover If it looks sitcky from inside then make it clean from an expert.
LindaWatson
by LindaWatson » Fri May 04, 2012 12:10 pm
It is better to check out with the expert in order to avoid the further risks.
It is currently Fri Nov 22, 2024 8:06 am
