Mystery undercarpet sheet
7 posts   •   Page 1 of 1
splutter
by splutter » Mon Dec 26, 2011 8:37 pm
Hi. I have just bought an old house with a 1960s extension. I lifted the carpet and underlay in one of the rooms yesterday, to discover sheets of an odd material nailed to the floorboards. I have attached two photos. It has been severly dented by feet of bed etc, so is obviously a bit pliant, but quite firm to walk on. It has a plastic or foam look to it, but it clearly full of 'fibres'. Can anyone tell me what it might be made of please, and its purpose? Thanks in advance. Graham
close up - looks fibrous
Dec 2011 024B.JPG (85.63 KiB) Viewed 3058 times
Dec 2011 023B.JPG (59.51 KiB) Viewed 3058 times
Re: Mystery undercarpet sheet
by welsh brickie » Tue Dec 27, 2011 7:58 am
its called fibreboard and used for sound insulation.
splutter
by splutter » Tue Dec 27, 2011 6:40 pm
Hi Welsh brickie,
thank you very much for this. Given the age of the extension, I was worried that the sheets might contain asbestos. Being for sound-proofing this is unlikely then, presumably? I'm going to lay new underlay and carpet. Because the fibreboard is so dimpled, I plan to remove it first. But can the hollows be filled somehow instead? Thanks again.
by welsh brickie » Wed Dec 28, 2011 9:43 am
no the holes cant be filled in,either replace or remove it.
splutter
by splutter » Thu Dec 29, 2011 7:00 pm
Thank you very much Welsh brickie, much appreciated.
diynovice123
by diynovice123 » Wed Jun 25, 2014 11:22 pm
I've just been taking up the carpet in our house and beneath the underlay there are a few clumps of hair/wool like material stuck to the floor. I'm concerned it may be asbestos. Has anyone come across anything like this before and have an idea about what it might be? I've attached a few images. Help much appreciated.
by welsh brickie » Thu Jun 26, 2014 12:13 pm
its looks like fibres from an old underlay, asbestos was not used to cover any type of flooring, it was mostly used for roofs, it is highly unlikely to be asbestos, use gloves and a partical mask as a precaution anyway
It is currently Mon Dec 23, 2024 12:44 pm
