by richardy »
Sat Dec 31, 2011 9:57 am
I have a problem with chains not cutting. I use a saw clamped in a steel horse to cut logs but after some time the saw will only cut the first inch or so and will not cut any deeper. I have tried sharpening, filing the depth stops, turning the bar but nothing works. A new chain works perfectly - the old one looks OK but is it just worn out? I have also noted the same sort of problem when using the saw out of the horse - it will only cut on the back stroke, very limited cutting on the forward stroke.
