15mm bath supply
soblue2001
15mm bath supply
by soblue2001 » Thu Jul 05, 2007 6:29 pm
hello all
is there anything fundamentally wrong with a 15 mm supply to a bath, as opposed to the 22mm, other than it will take longer to fill?
On a combi system if that matters.
Thanks for any advice.
Allan
oldie
by oldie » Sat Jul 07, 2007 11:51 pm
A typical bath can be about a 100 litres. A typical header tank system with stored hot water and 22mm pipes to the bath can fill it at 20-30 litres a minute. i.e between 3 and 5 mins.
With sufficient pressure a 15mm pipe could easily deliver 15-20 litres a minute but as your combi is probably only capable of producing about 12 litres of hot water a minute, then that is the limiting factor and is why it will take so long to fill your bath.
Regards
soblue2001
by soblue2001 » Mon Jul 09, 2007 2:55 pm
Oldie,
thanks for the reply
Allan
It is currently Sat Nov 23, 2024 3:59 pm
