Toilet not flushing - help!!
cm75
by cm75 » Tue Mar 13, 2007 9:46 am
I'm looking for some tips regarding my dodgy toilet.
Recently I was forced to change my toilet handle as the plastic holding bolt cracked.
Since fitting the new handle, the cistern does not empty when I flush. I have checked that the handle is correctly positioned and that the lever arm is fully extended when the handle is pushed, but the water does not drain. Sometimes if I rapidly press the lever several times, the water does drain and the toilet flushes. However, this tactic has stopped working the past few days which has left me having to slop out!!
In an attempt to identify the problem, I removed the handle completely and manually tried to flush the toilet by pulling the lever arm, but this also did not work, and therefore leads me to believe that it's not the toilet handle that is the problem.
The cistern is filling ok and reaches the required level, so I'm at a loss why it has suddenly stopped draining.
Anyone got any tips on what might be the problem and how to solve it?
cheers
thedoctor
by thedoctor » Tue Mar 13, 2007 6:19 pm
Sounds like the diaphragm in the flush unit has split. Take a look at the projects section , Cold water tanks. Details of how to replace it are in there
thedoctor
by thedoctor » Fri Mar 16, 2007 2:09 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Thu Jan 02, 2025 10:38 pm
