plastering on render
1964taf
by 1964taf » Wed Jan 11, 2012 7:22 pm
i recently had a damp problem which i cured by taking off the old plaster back to the brick and rendered with sand and cement with a water proof liquid and then plastered. now three weeks later the plaster coat has not bonded to the render.can any one give me a solution for getting the plaster to stick cheers andy
tomerny1
Re: plastering on render
by tomerny1 » Fri Feb 03, 2012 6:37 pm
HI THERE. YOU NEED TO FIX DAMP PROB FIRST. AND MAKE SURE ROOM IS AIRED ALL THE TIME E.G, WINDOW SLIGHTLY OPEN. BEFORE AND AFTER PLASTERING. ENJOY
by welsh brickie » Sat Feb 04, 2012 7:13 am
the waterproofing in the render has repelled the plaster,A waterproof addative should only be used in the mix to render externally.Scrape of the finish plaster and heavily paint the area with a pva solution.Then plaster using thistle multi finish.
It is currently Tue Nov 26, 2024 9:21 am
