Cold mains supply to a mixer power shower??
ECRyder
by ECRyder » Sat Jan 14, 2012 2:51 pm
I live in a bungalow and want to install a power shower with the hot supply only pumped separately, and with cold supply to the mixer valve coming from the rising mains (rather than from a cold storage tank). Can I do it and does it work??
Thank you
plumbbob
Re: Cold mains supply to a mixer power shower??
by plumbbob » Sun Jan 15, 2012 5:08 pm
ECRyder wrote: Can I do it and does it work??
Very few models of mixer shower will allow unbalanced feed pressures. Personally, I avoid them anyway because of the increased risk of scalding.
There are several other negative reasons for not using unbalanced feeds so avoid it if at all possible.
Dick Puller
by Dick Puller » Sun Jan 22, 2012 4:26 pm
You could use an equalizer for this, but as said it's not wise to supply a shower valve with unbalanced pressures or flow rates.
It is currently Sun Nov 24, 2024 2:06 am
