Head of water
ECRyder
Head of water
by ECRyder » Sat Jan 14, 2012 3:07 pm
I know the head of water is determined by the height of the water level above the ground ie 10 metres high gives 1 bar pressure at ground level - but is that head altered by the amount of water in the storage tank? For instance will a 50 gallon tank of water gives 2 bar of pressure if sited at 10 metres above ground.
NB This is a novices question !
Thank you
Barry Bunsen
Re: Head of water
by Barry Bunsen » Sat Jan 14, 2012 9:03 pm
Water head pressure is static pressure caused by the weight of water solely due to its height above the measuring point. The pressure at the bottom of a 40-foot lake or a 40-foot high thin tube would be identical, since only height is involved.
I just got this from the internet. It explained the point better than I could
It is currently Fri Nov 22, 2024 2:23 am
